Show only
Search instead for
I have attached a dwg using the out-of-the-box template and can't get the door tags to display properly even though the schedule reads correctly.
What's the trick to seeing the door numbers?
Adam
Hmmm, strange. When I open the drawing I see door 100, 101, 102 from left to right. Try releasing the door tag anchor and then re-anchor it to the door.
Edited by: jkrieg on Jun 16, 2009 9:37 AM
I'm open to suggestions. Perhaps I'll just switch to Revit. 🙂 It'd be funny if it weren't so annoying. Starting to wonder if a reinstall is the answer. When I did first install it was along side 2009, then uninstalled 2009. This has been usual M.O. though with new releases.
They show up fine for me. A reinstall or repair install seems to fix most
things for me.
wrote in message news:6202624@discussion.autodesk.com...
Is this happening only in this drawing or any drawing in which you are placing door tags? You might try the command "objrelupdate" first before the repair/reinstallation.
