Hi, I want to know if there exists some way to fade a dimline style, as the same way i can fade Layers with layoff etc.
I will explain my problem... for example, I have two dwg files with his respective dimelines styles, for example
1--50 and 1-50, i mean they have the same name, but sometimes i had edit one of them (in one dwg file), so, when i copy a draft with dimelines to the file that i have no edit the dimeline style, then i have two dimeline styles (but with the same name). So in that point i want to turn off, fade or isolate one dimeline style (the one there i dont want) so i can erase it.
One of them says "linear"
Im sorry if its kind of dificult to understand, but english is not my first lenguaje.
I can try to explain it again.
Thanks for your help.
