AutoCAD Architecture General
New Member
Message 1 of 3 (248 Views)
Different Default walls in AutoCAD Arch 2013
248 Views, 2 Replies
10-04-2012 08:54 AM
I'm running a lab in a school and when we draw walls some students have green walls, some have teal, some have wide hatch pattern, and some have tight hatch pattern.  They all sort of act differently when placing doors and windows in them and when you select them I can't find any difference between them on the Properties Palette.  Anyone know why the default would be different for each computer?
leothebuilder
Message 2 of 3 (241 Views)
Re: Different Default walls in AutoCAD Arch 2013
10-04-2012 03:12 PM in reply to: tmaccartney
Are you sure all users are using the same wall style.
Are all users starting with the same drawing template.
Do all the users have the same display configuration e.g. low detail, medium detail, high detail etc.
Explain how the walls act differently when placing doors or windows.
If some show as green and some show as teal, do all the users have the same type of computer and graphics card.
Message 3 of 3 (232 Views)
10-04-2012 09:05 PM in reply to: tmaccartney
Do all users have the same drawing scale set current?  2013 introduced annotative component hatch for ACA objects, including Walls.  If the Wall Style being used has an annotative hatch active (in either the Wall Style or in the Material Definition, if the display is being controlled by material), different drawing scales will result in different hatching.
David Koch
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
