My detail component manager in AutoCAD Architecture 2011 was working fine until I installed Revit 2013 on it (as part of Building Design Suite 2013). I have tried uninstalling and reinstalling MS .Net framework, but it has not helped. Any ideas?
Thank you for your post. In this case I would recommend a simple repair via the control panel for your AutoCAD Architecture 2011 software. In some cases where the newer software is installed (and depending on overall environment configuration) the registry that the program relies heavily on can be affected and then a simple repair is needed to correct the issue. Please test this first and let us know in the community how this worked out. Thank you.
One additional thought (and item to watch) is the presence of MS .Net Framework 4.5. If this is present in this configuration you can try removing this and then installing .Net 3.0 (with SP1 used in 2011 software) to then test overall communication and access. Please keep us posted and let us know how this worked out. Thank you.
I wanted to check back in with you on this past and see if the previous information was helpful and see if further assistance is still needed within the community. Please let us know so we can best assist where applicable moving forward.
