AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Detail Components, can the Batt Insulation be modified at the end?
1 REPLY 1
Jason_S
5080 Views, 1 Reply
I thought there was a way to get Batt Insulation to taper at the end and still keep the Batt loops while going smaller.  Is there a way to do this?
See my attempt to draw it attached.
1 REPLY 1
alw2007
in reply to: Jason_S
Ok, so after playing around with it again, I figured out where I went wrong.
To Taper your Batt Insulation...
- Go to Detail Component Manager
- Select Thermal/Moisture Protection ->Thermal Insulation ->Batt Insulation->(Whichever R-Value You'll be using)
- Select your starting point for your insulation then select your alignment (Right, left, center)
- Select the end point for your insulation (2nd point)
- Hit "Enter"
- You'll be prompted with "Select First point of first Taper Boundary"when you are, pick your top boundaries. - (so if you want to taper the right side from 12" to 6" starting 2' from the end, pick a point at the 12" height  2feet away then pick a point 6"high at the end of your insulation line.)
- DON'T Hit "Enter"
- Then select your top boundaries of your second taper point in the same way.
(See Attached image for Clarification)
Hopefully this helps!!
~ALW
”Boost
