When I try to open my detail component manager, I get the following message: Cannot open database C:\ProgramData\Autodesk\ACA 2010\enu\Details\Details US\AecDtlComponents (US).mdb. The actual .mdb file is in that location but it wont load it. I also tried to add it under options\aec content, but it would not allow this either.
I had a similar problem a while back when accessing legacy files created using older versions of ACA.
This is the assistance which I received:
The Solution with thanks from Sam Chan - Autodesk via ACA Discussion Group
Hi Bill,
Please try the following things and let me know what you find:
1. Get the old mdb files (the one you used before the upgrade)
2. Copy them into other location
3. Add them/register them using Options dialog
This worked for me ... some of my observations following that ...
Note the following:
Previously I was getting a message at the command line "AEcDtlCompManager There are no Detail Component databases specified. Please set databases at the Aec Content tab in the Options dialog".
In fact I had registered a data base. I needed to copy the full directory - not just the mdb file. When I tried it the 1st time after copying just the mdb file it came up with an error - it was looking for an xml file. I needed to unload the previous database before registering the old one as I was getting a message " a database with the same GUID ***** already exists".
Just to test it again - I reversed the procedure & went back to the old mdb file - and the old situation re-occurred.
We use a shared directory on our server for coordinating our DCM. I have created an "old database" directory adjacent to the new one so in future (when / if this happens) I can instruct the user to use this one instead.
I anticipate that this will only be when using old legacy projects.
I hope this helps With thanks to Sam Chan
Bill Tapp
