AutoCAD Architecture General
crocra
Message 1 of 4 (208 Views)
Design Center
208 Views, 3 Replies
05-23-2012 06:42 AM
Why is the design center not coming on screen. When I press the button, the command says adccclose
Active Contributor
Message 2 of 4 (200 Views)
Re: Design Center
05-23-2012 11:08 AM in reply to: crocra
In your command line type  DC  and see if that helps...
crocra
Message 3 of 4 (166 Views)
Re: Design Center
05-24-2012 05:42 PM in reply to: crocra
No, it does not work, nothing happened. In the ribbon insert, when I press the button Design center the command says:adcclose
pendean
Message 4 of 4 (160 Views)
Re: Design Center
05-25-2012 06:37 AM in reply to: crocra
ADCCLOSE closes design center: so open CUI command, navigate to the button you pushed and see if the macro code there has been changed to only do the 'ADCclose' function.
Otherwise, did you recently change from a dual-screen setup or someone take away an external or additional monitor you used to use? It's probably still parked over there and you cannot find it to use it.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Ask the Community
