Anyone know how to put on the prints, an automaticially updating date and time stamp? I have 2012 installed on my computer, I have used the field command, but it does not automatically update the date and time, when you print, edit, or modify the drawing. I do know that if you publish, your drawings, you can put the date and time stamp on it, but If you print a layout tab one at a time useing the plot command, you do not have the option to print the date and time stamp?
Solved by krybuk. Go to Solution.
Solved by David_W_Koch. Go to Solution.
Check your settings. In 2010, these are found in the Options dialog, User Preferences tab, Fields area in lower left, Field Update Settings button. Click that button, and, in the Field Update Settings dialog, you can toggle whether fields update for a number of events: Open, Save, Plot, eTransmit and Regen. (Location and options may vary in 2012.)
I would hope that if you have Plot checked, that the field values would update when you plot.
I could not get anything to update, you insert a field and it becomes mtext, went thru the options, everything looks good there also, but I did see the when I plot there is a spot to add time date stamp, so I'm just using that. Thank you
If this is just for prints to have a date stamp, the easiest thing is to turn the Plot Stamp on. In Plot- Plot Options on the right side - Plot Stamp - needs to be checked. Click on the stamp symbol to tweak the way the stamp looks. You can set it to display file name and path, date, time of plotting and user name...
I cannot find any of these options buttons etc.... where are they?
We'd like t ohave time/date stamp work for us too. Used to have one and trying to get back on again.... Greg
yeah, never could get a date and time stamp to work again, but when you plot you can check the box that says plot stamp on, and can also change the setting for the plot stamp, it's a little different, but it works
Here's a plot stamp block that we use. It actually has an RTEXT data defined in it and I believe Express Tools must be loaded for this to work. It's 100% automated and will show the current drawing, plot time and date, the user who plotted it and will show attached xrefs and paths.
Same one I use, in 2012 my express tools are loade, but I still cannot get mine to work, not sure, even yours when I open it, does not work
Hey
Devid
I change in Field update setting setting Auto Cad
but still I am not able to Print Updated Date and Time Stamp.
You can also E-mail me at sagarsanchaniya3@gmail.com
or Call +91 99133 39354 or Whats-app.
