AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Customization name does not exist?
3 REPLIES 3
LisaDrago
526 Views, 3 Replies
Okay - my client is having an issues when she opens AutoCAD Arch that the attached image shows up...
I have never seen this before, but then I did not do a lot of customizations
Any ideas??
Thanks!
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
3 REPLIES 3
pendean
in reply to: LisaDrago
Unless they changed it, that's the primary CUIx file when they are using the ARCH profile. Looking at your other post, did they make the mistake of "migrating" from 2012 when they started 2014? Time to put 2014 back with a reset.
LisaDrago
Yes - we did try migrating - It did not work. Obviously. Smiley Sad
So resetting will fix this?
I saw in the start menu>all programs> AutoCAD 2014(I don't have ACA installed)> reset setting to default.
This will fix this issue?
Thank you!
LD
pendean
Yes: or a repair reinstall will do it too.
”Boost
