Okay - my client is having an issues when she opens AutoCAD Arch that the attached image shows up...
I have never seen this before, but then I did not do a lot of customizations
Any ideas??
Thanks!
LD
Solved by pendean. Go to Solution.
Unless they changed it, that's the primary CUIx file when they are using the ARCH profile. Looking at your other post, did they make the mistake of "migrating" from 2012 when they started 2014? Time to put 2014 back with a reset.
Yes - we did try migrating - It did not work. Obviously.
So resetting will fix this?
I saw in the start menu>all programs> AutoCAD 2014(I don't have ACA installed)> reset setting to default.
This will fix this issue?
Thank you!
LD
