All,
We have a problem with a custom created staircase, see attached drawing (in ACA 2012). For some reason this staircase created using the "create from linework tool" fails to change when we change styles. You'll also notice that the risers/treads don't display properly
All help greatfully received.
kind regards
Ben
I could be wrong but I haven't found custom built stairs from linework very flexible once created. Generally a linear process in one direction.
I believe that the custom stair down was not created in the correct order, which is affecting how the treads don't display. You would want to start at the current level going down, not at the lower floor going up to your working level. When it is created that way, you would set that stair's vertical orientation to down, elevation 0. That would help some of the display issues IMO.
Mary, Nathan,
Thank you for your prompt responses. We've tried to redraw and it appears if we have too many winders then the stair tool "falls" over. Adesk any ideas?
Kind regards
Ben
Have you considered multiple stair objects for each flight of stairs? Not ideal of course. Which method of creating custom stairs are you using, linework or treadprofile? If you haven't tried one of them maybe give it a go.
Mary,
We normally use the linework to stair unless it's a straight flight. We have tried (over the years) to get the winders to work but they simply will not play ball. We've tried multiple objects however we do a lot of customer modelling and when it comes to modifications this is a lengthy process hence the linework to stair option.
We think we've found the issue on this one and that is the number of winders on the corner, 3 works fine but 4 causes the remaining treads to disappear
Ben
Hi Ben,
I see that you recreated the stair in question, and that when you include more than 3 winders, the remaining treads disappear.
If the issue is only with the display of the stairs in Plan, have you tried adjusting the Cut Plane for the stair?
Victoria,
The winders only disappear in plan, in 3D the staircase displays correctly.
I attach the latest drawing in ACA 2012 for you to test
Kind regards
Ben
Hi Ben,
Thanks for posting the file. I'll take a look, and see if I can come up with something that works for you.
