As I continue my learning of AutoCad on the PC after having been a Mac CAD (non-AutoCad) user for 15+ years, another question has cropped up. My boss wants the circular "heads" of the elevation and sectional callouts to be smaller on the finished drawings. How can I control (or override) the default size of these? Or do I need to override on a case by case basis? I've searched these and other forums and what I am getting a sense of is that AutoCad controls those sizes pretty tightly so they remain annotative and AutoCad sets them at the size it thinks they should be and changing that size is not a simple process. Thanks in advance for any assistance!
In doing some digging, I am wondering if either of these is an option:
A) If I launch the Design Center and look under Blocks, I see blocks for "Anno_Section_A2" and "Anno_Elevation_A2". If I double-click these, I get an "Insert" dialogue. There is a "Scale" section - but there is only an ability to alter the X scale (which is "1"). The Y and Z options are greyed out. Would I scale the callout heads here?
or
B) In the callouts palette if I right-click on a callout, such as "Elevation Mark A2" I see in the "Tag and arrow location" field of the dialogue that there is a pointer to the file "C:\ProgramData\Autodesk\ACA 2011\enu\Styles\Imperial\Callouts (Imperial).dwg". If I go to this dwg file on the hard drive and open it, I see all of the callouts in model space. Can I edit the sizes here (after first making a backup copy of this file in case I need to restore later)?
Am I on track with either of these routes?
Additionally, I pulled out hard copies of some past drawings, and the sizes were smaller on those and are what my boss is looking for. The only change since those drawings is that the engineering department has given me their template drawing so I would have their layouts, the correct title block, the company text styles, etc (I am fairly new to this firm). Could it be that this new template has the larger sized callout heads than the default ACAD Arch drawing template that I had been using these previous weeks? If that is the case, then where do I edit the callout sizes assigned to that template?
Again - thanks in advance for any and all assistance.
