Is there any way to turn off the Contextual tab state. I tried changing a lot of them in the CUI Ribbon Properties from Full to Merged but now when I select anything the program slows down to a crawl. My reason is that its really not that convenient for ACA to keep switching back and forth just because I select an object. I use a lot of hot key’s but there are many commands on the Home Ribbon tab that I use 99 percent of the time at selection and I find it a royal pain in the ars to keep switching it back to get to the command I need. I’m using 2011 ACA. OS is Windows 7. 64 bit and 10 GB of Ram Thanks Todd
