My content browser doesn't have the original options it used to have, instead it has a customized version. But the customized version does not have anything in it. How do I get it back?? No matter where I search in CAD or in my files I can't find the original. Do I have to uninstall and install the program again?
Thank you!
Brea
You could try the following and check if this resolves the issue.
*Go to Manage/Cui, right-click ACA and select Reset ACA.cuix.
*Go to Options/Profiles and with your profile highlighted, select the "Reset" option
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
That just changed all of the tools at the top so I can't find anything anymore and when I type "contentbrowser" into the command line it still hasn't changed. Any other suggestions?
