Solved by LeafRiders. Go to Solution.
Solved by David_W_Koch. Go to Solution.
I own a Logitech "M570" track ball mouse and it has two additional buttons. One for "forward" and one for "backward" which work in the web browser and when browsing through files and folders on the computer. Is there a way to make these buttons usable for commands in Auto CAD? I love the functions out of CAD and when looking for saved files with in CAD but if commands could be assigned to them it would great. Any feed back is greatly appreciated. Here is the mouse I am using M570 Mouse
Thank You.
Does the driver for the mouse allow for assigning custom keystroke(s) to those buttons? If so, you will want to see if it also allows for customization on a program-by-program basis, to preserve the forward/backward functionality outside of ACA.
If your mouse driver can be so configured, do the following:
1. Identify an unused keystroke sequence that is not being used for anything else in ACA (or which you are willing to lose in ACA). Run the CUI command and, in the Customize User Interface dialog, on the Customize tab, in the Customizations in "XXX" pane, click on the Keyboard Shortcuts node under any customization file to see the currently defined Keyboard Shortcuts. (For my own use, I chose to use CTRL+F12. I do not recall if it was already in use or not.)
2. Determine if the command you want to run is already defined in one of your loaded customization files (Command List pane). I have my 5th button set to run CTRL+F12 and, in order to have it display the SNAP popup menu, I created a custom command in a custom partial CUIX file that I created to hold my own customizations, which I called Snap Menu. That command is assigned this macro: $P0=SNAP $p0=*
If the command you want is already defined, you can use the existing definition. There is a Snap Menu command in the ACA CUIX - I no longer recall why I created on in my custom CUIX. (Perhaps in the version in which I originally created it, either it did not exist or I could not find it. Or maybe I just wanted everything in one CUIX file.)
3. Decide in which CUIX file you will create the Shortcut Key definition. They do not need to be in the Main CUIX file - I put mine in the same partial CUIX file that has the command definition (to make the migration to future versions easier). Expand that CUIX's node in the Customizations in "XXX" pane, then expand the Keyboard Shortcuts node.
4. Here is the secret handshake part. I can not tell you how many times I tried to create a new Shortcut Key by right clicking the node and expecting to find "New" as a choice. What you need to do instead of that is find the desired command in the Command List pane, and drag-n-drop it on the Shortcut Keys node in the All Customizations "XXX" pane.
5. Select the newly added command under the Shortcut Keys node. In the upper right side, in the Shortcuts pane (use the arrow key in the lower right corner if you need to expand the dialog to show the panes on the right side), you should find your newly added command with a horizontal line icon in the left column. Click in the Keys column on the line with your custom command and press the desired keystroke to add the key sequence and to change the icon to a check mark.
6. Click OK to save the changes to your CUIX file.
7. Once you assign the keystroke sequence you entered in the Keys column to one of your extra mouse buttons, using that button should run the command. I can click my fifth mouse button with my ring finger, so the Snap popup menu is only a mouse click away when I want a specific OSNAP override.
AutoCAD has basically a set of commands that already have assigned keyboard shortcuts. Go to your CUI and check them out. You can create a new one by right-clicking the Shortcut Keys heading. Then within your mouse setup assign that key stroke to that mouse butotn. I personally like the "undo" command assigned as one of mine and CTRL+Z is what I placed into the Logitech SetPoint software and it works like a charm.
