AutoCAD Architecture General
Valued Contributor
Message 1 of 3 (64 Views)
Column Grid is to sensitive help.
64 Views, 2 Replies
04-27-2012 12:42 PM
Every time I hover near a column grid it auto selects and is crippling my workflow. I basically have to turn it off to work. Is there a way to desensitizes a grid object?
Typically If I want to change or select a grid I would just pick it. In ACA 2012 I can’t get near it or it selects itself.
Todd
MarySeufert
Message 2 of 3 (60 Views)
Re: Column Grid is to sensitive help.
04-27-2012 01:32 PM in reply to: ktttallen
Do the grips show up or is it just showing up highlighted/dashed? If no grips are showing up you are just seeing the hover selection preview visual effect. To disable this go to Options -> Selection tab. Under selection preview make sure 'When no command is active' is un-checked.
~ Mary
_______________________________________________________________________
Normal people believe that if it ain't broke, don't fix it.
Software Engineers believe that if it ain't broke, it doesn't have enough features yet.
Valued Contributor
Message 3 of 3 (56 Views)
04-27-2012 03:00 PM in reply to: ktttallen
That was it, Thank you!!!
I upgraded from adt 2004 a year ago and I’m still having a hard time with all the new system variables.
No complaints though, just a lot to learn and no time to spare.
Thanks again:smileyhappy:
Todd
You are not logged in.
Ask the Community
