I realise I am exposing my weaker side here but am I the only poor sucker who has closed the drawing (without saving) instead of closing the block editor after abandoning an edit to find I've just lost my last 3 hours of work?
To put it another way
(*&$&**## &**& ) @@ *&^^%_#)(#$(# ^(&** ^&%*^&(*(&&*$#$() removed due to not being suitable for publication.
Am I the only one who thinks this is a REALLY REALLY BAD design decision to expose the close drawing cross (top Right) inside the block editor? At the very least, an extra warning that I am not saying "NO DONT SAVE BLOCK EDIT" but "NO I AM AN IDIOT THAT INTENTIONALLY CLOSES THE WHOLE DRAWING FROM THE BLOCK EDITOR".
sigh !!
I confess that I have done the same thing and also complained about it to no avail. Try to remember to save before bedit.
Alternative solutions:
1. Undefine the close command. But you would need to enter .close to close your drawings.
2. Redefine the bedit command to temporarily undefine the close command. Use a command reactor tracking bclose to redefine the close command.
I've moved the command line over the close drawing X. I've hit it accidentally too many times even when not in the block editor. Since I can't touch it, it is no longer an issue!!
You may also use BE to open the blockeditor and bclose to close the blockeditor. I guess that there are a great deal of us that are keyboard users and Toolbar or ribbon users. I personally have never used the ribbon and have never been much or a toolbar user either.
I am an avid keyboarder but I have never used it for the very simple commands like file open / close etc. I use the pulldowns and I do have the ribbon curled up but do use it occasionally. I do use toolbars with simple macros. A toolbar with a ' in the macro can interrupt a present command without stopping it, say for resetting snaps.
But what's telling again is I'm not hearing a good reason for the X displayed in the block editor and that others have made the same mistake. Maybe it could be as simple as a tick box to turn the X off, either in the BE or all together.
I'll try Mary's idea but that does make the text box floating and I have read that can slow some things down or break something else - so we'll see how it goes.
I do other things that are supposed to slow you down too... Properties palette is docked on my second monitor, Layer Props is also open but minimized all the time. The only time I have slow downs is when it autosaves and switching to 3D views on really big buildings. Specs below and screen shot of my ACA 2012 setup attached. Civil3D is also setup similarly, and since it is heavy on ribbon usage, I've gone to the dark side and use the ribbon all the time. I'm not sure how I'll set up 2015 after SP1 comes out, but it will be different considering all the UI changes they have made.
Building Design Suite and Civil 3D 2012 - Windows 7 Professional 64 SP1
Dell T3600 - Intel Xeon 3.6 GHz - 16GB RAM - NVidia Quadro 2000
ha! I am the NA! I'm trying out Mary's suggestion of overlaying the text box over the X and it seems to have some sense.
