AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Change material definitions to CTB format?
1 REPLY 1
Jason_S
302 Views, 1 Reply
Is there a way to change the material definitions to CTB format in the plot style under the material style?  See attached image.
I have a client that wants everything in CTB format and in AutoCAD Architecture.  I can get the drawings into CTB but the materials plot way too heavy and when I go in the styles they show Full Saturation or Wide, Thin from the STB plot styles.
The Drawing is in CTB and I am pulling my hair out trying to get the couple materials used set to Color based plotting.
Thanks for the help in advance and it is much appreciated.
1 REPLY 1
David_W_Koch
in reply to: Jason_S
Notice that the Plot Style column in the material definition in your image is grayed out. In a file that uses color-dependent plot styles (CTB), the plot style is assigned by the object color. You will either need to change the color of items that are not plotting as desired to a color that has the desired plot characteristics, or create/edit a CTB plot style file that assigns the desired plot characteristics to the color used in the material definition. Or, you may be able to find an out-of-the-box CTB file that works with your Material Definitions.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
”Boost
