I have modeled a house with some colums supporting a deck. Ideally I would like my colums to be round with a spiral twist.. But would be happy to know how to change the default square into a round colum.
Thank you for your time.
Solved by David_W_Koch. Go to Solution.
You can define a new Structural Member Style, with a round profile of the desired diameter, and then change the style of your columns to your new style. The easiest way to do that would be to use the Structural Member Wizard, which can be accessed on the Manage ribbon tab, on the Style & Display panel. Select the panel title to show the full panel and select the Structural Member Wizard tool.
Choose the concrete round column, and provide the desired column diameter and style name.
Then select all of the columns you want to change and use the Properties palette to change the style to your new style.
