I'll give it a shot over here as well...
The thing is.. I like to attach a .aim or import a inventor DWG into a section and a plan in autocad.
But how do I select the right orientation on import? The default Inventor view is a sideview and won't work on a plan.
Right now it seems like I either have to go into 3D model view and rotate the object or have to change the orientation Inventor for plan and then reorientate it for section...
Isn't that a little odd?
