AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Change DXFOUT settings?
2 REPLIES 2
Mike.Lamka
678 Views, 2 Replies
Is there any way to adjust the setting that DXFOUT uses so it does not bind xrefs or exlpode AEC objects? This is in references to ACA 2012.
Thank you,
Mike Lamka
2 REPLIES 2
Laks-Autodesk
in reply to: Mike.Lamka
I believe there is no settings to change the DXF output options you're looking for out-of-the-box in AutoCAD Architecture.
Lakshminarasimhan Seshadri
Mike.Lamka
in reply to: Laks-Autodesk
Thank you
”Boost
