I have student version of AutoCAD Architecture 2012. I'm following the tutorials in aca_imperial_tutorial.pdf file. When I try to the restroom layout into the drawing, I get the "** Canceled - Educational Plot Stamp in source drawing. **" message. How can I fix the problem?
See if the information in this link helps.
If you have already tried both a repair and a reinstall and neither have solved the problem, it's most likely because you have remnants of the software remaining on your computer. There are several products that assist in removing all the remnants left over from an uninstall. The program that I have used (which has a free trial) is Revo Uninstaller http://www.revouninstaller.com/.
