AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Can't change the colour of the sun
7 REPLIES 7
Message 1 of 8
BrianDroy5657
2329 Views, 7 Replies
I can't seem to change the colour of the sun. Its stuck on a strange shade of brown.
Also I created a new material. It was a shade of grey metalic paint. Except that it appears to have a red tint.
Any ideas?
7 REPLIES 7
Message 2 of 8
Hi Brian,
If you change the system variable LIGHTINGUNITS to "0", you should be able to change the sun color.
For reference, the options for this system variable are:
0: No lighting units. Standard lighting enabled.
1: American lighting units (foot-candles). Photometric lighting enabled.
2: International lighting units (lux). Photometric lighting enabled.
Please let me know if this fixes the issue for you.
Victoria Studley
Content Experience Designer - Fusion 360
Fusion 360 | Learn & Support
Documentation | Contact Support
Message 3 of 8
rhw
in reply to: Victoria.Studley
Changing lighting units to 0 allows for the sun color to be changed.
Message 4 of 8
Briliant! Thats much better thanks! This has been driving me nuts.
You're a genius Victoria
Tags (1)
Message 5 of 8
rsuverk
Where do OI find lighting units?
Message 6 of 8
David_W_Koch
in reply to: rsuverk
@rsuverk
Type LIGHTINGUNITS at the command line, and press the ENTER key.  It is a system variable.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 7 of 8
So, in newer versions of AutoCAD, LIGHTINGUNITS can't be changed to 0.  So, then the original question: how do I change the sun color?
Message 8 of 8
pendean
in reply to: tshelleman
In current releases the color of the sun changes with the day/time, no other option exists.
The alternative you have is to turn off the sun and create a distant light instead.
And for your follow-up question https://forums.autodesk.com/t5/autocad-forum/how-to-change-sun-colour/m-p/9404046#M1014727
”Boost
