style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<stephenherridge1887> wrote in messageCan
href="news:6180267@discussion.autodesk.com">news:6180267@discussion.autodesk.com...
a block be anchored to a wall and if so how is this done?
Stephen
<stephenherridge1887> wrote in messageI
href="news:6180523@discussion.autodesk.com">news:6180523@discussion.autodesk.com...
would like to anchor a block so that it will move with the wall when I have to
adjust the wall. Stephen
Is there any way to create an mvblock, like an electrical switch or receptical, that automatical anchors to a wall? Using the object anchor tool works great, but its an extra step. I'd like to be able to plop in these electrical symbles like wall tags so that they are automatically anchored to the walls, then if I need to anchor a switch to a particular door, I can use the anchor tool.
Not an answer to your question but an observation. If you are doing a lot of electrical work and actually show circuits and panels, you might benefit from using AutoCAD MEP which uses an object called a device (like an mvblock) for outlets.
That is an option, but talk about an extra step! Since I do a lot of smallish residential work, I'd rather not have to use AutoDesk's entire suite of software to put together a set of plans. Just for the sake of being curious, and always wanting to know more, how would that work anyway? Would I draw the architcural stuff in Architecture, then attach these 'devises' to an xref'ed (?) version of the plan in MEP? Would they then move with the walls if I change things around in Architecture?
It depends on how you like to break up the project. You could actually use MEP to do all the work. It contains ACA and AutoCAD. It has added display configurations to half-tone the architectural components with respect to the PME stuff. I believe it anchors through xrefs but don't have it with me at the moment.
