AutoCAD Architecture General
Impact
Message 1 of 3 (454 Views)
CREATEHLR is crashing AutoCAD Architecture
454 Views, 2 Replies
06-09-2012 04:44 AM
Whenever I select more than one or two simple objects in AutoCAD Architecture 2013 and try the CREATEHLR command, CAD crashes.
This is true from the Model tab, other tabs I've set up, and regardless of view.
I've audited the drawing.
I've done an installation repair.
I've been sure to use the ACA profile.
The error message is:
Fatal Error:  Unhandled Access Violation Reading 0x000 Exception at e3d57cb6h
LanceEdwards13
Message 2 of 3 (401 Views)
Re: CREATEHLR is crashing AutoCAD Architecture
06-14-2012 12:16 PM in reply to: Impact
There is a known issue with the Section and Elevation tool in ACA 2013 that has been corrected by the hotfix below. This issue has also affected the CREATEHLR copmmand.
http://usa.autodesk.com/getdoc/id=DL19248702
Install the hotfix and report back.
Lance Edwards
Product Support Technical Specialist
Product Support
Impact
Message 3 of 3 (395 Views)
06-14-2012 01:18 PM in reply to: LanceEdwards13
Thanks, Lance!
That did the trick.  I tested it several times with no errors, crashes or problems.
Kudos!
- Dave
You are not logged in.
Ask the Community
