AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Bugs in Autocad Architecture 2013 part one
4 REPLIES 4
arch
376 Views, 4 Replies
Can you explain me what I do wrong? http://www.youtube.com/watch?v=40Yw2rRY8xw&feature=plcp I cant set the hatch in quick cross section in the wall. I have installed sp1 for ACA 2013. It nothing change. I'm architect from Poland.I use Autocad Architecture five years. I get active subscription. In ACA 2012 this problem not exist.
4 REPLIES 4
arch
in reply to: arch
another error. I can't copy to clipboard my styles that was created in ACA 2012
see the video
http://www.youtube.com/watch?v=u4pU71kg1aQ&feature=youtu.be
applies to walls, doors, stairs, slab , multiblocks created in ACA 2012. Even when I'm saving the file as 2013 dwg.
Now I'm in bad situation. I have changed all my projects to 2013 dwg ver. Autocad Architecture 2012 now is unusable.
All of my files, styles, palets and AEC objects are now in 2013 format. I have to work but I can't.
arch
in reply to: arch
I can't use local edition. the walls disappeared.
see video.
http://www.youtube.com/watch?v=Ap0QF2qAJDI&feature=youtu.be
arch
in reply to: arch
Can You explain me, what have You done with this ACA in version 2013. It's worse than ACA 2012!
Can You give me a program to change back ACA 2013 to ACA 1012 without compatible problem?
ps. it's not even all the errors that I found.
arch
in reply to: arch
it's anyone there who can help me?
HELP!
”Boost
