AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Bug found so far in Architecture 2015
6 REPLIES 6
E-Lavoie
516 Views, 6 Replies
Number of zero before the number in schedule table, on the tag it read 001, but on the schedule it read 2. I can’t make it to do 002. Never had this problem before 2015. I tryed to change the zero pading in the Property data formats, but it dont work.
Erased linework on 2d section/elevation. Each time I refresh the lines erased comes back and I have to erase all of them again.
On this forum, my name show as Yves, but it should be Etienne, Yves being my boss :P, I tried to change it in the edit account or preference, but it don’t work.
6 REPLIES 6
subsales
in reply to: E-Lavoie
Hi Etienne, Your report is really appreciated, our team has confirmed both of issues, and will research as soon as possible. Thank you very much. Pengfei Tian AutoCAD Archiecture
Pengfei_Tian
Hi Etienne,
Our team are investigating the issue, to make sure tackle the problem totally, would you please send us drawings indicating the problem?
pengfei.tian@autodesk.com
Thanks and Best Regards,
Pengfei Tian
E-Lavoie
in reply to: Pengfei_Tian
Wich one, the schedule problem or elevation problem ?
Pengfei_Tian
Hi Etienne,
Thanks to your quick reply, it is for Elevation problem.
Best Regards,
Pengfei Tian
E-Lavoie
Here you go
Pengfei_Tian
We will investigate it.
Pengfei Tian
”Boost
