I am not sure if I am asking this in the right forum or not, if not please let me know.
I have 2 identical drawings, Each drawn in model space with one tab named Layout 1 with nothing on the paper tab.
I create the first drawin with it set to PDF, the name it comes up with is
"006-50_21-LIGHTING PLAN Model (1).pdf"
this is what it has been since I started using autocad.
I create the second with it set to PDF, the name it comes up with is
"006-50_21-LIGHTING PLAN.pdf"
if you notice it doesnot add the tab name to it. I want the second without the tab name, anyone know what setting to make this happen all the time.
Hi 1bdchristian,
I understand you'd like to save PDFs without the "Layout (1)" tag appended to the file name. The simplest solution I've found to this problem is to use the Sheet Set Manager. It provides more versatility in naming your files, and leaves no guesswork in how your PDFs will be names when you plot them.
I'm attaching a couple of images to this post to demonstrate how this works.
You can also find more information on setting up, using, and plotting Sheet Sets via the following links:
To Publish a Sheet Set File to PDF
To Publish a DWF, DWFx, or PDF File Using Publish
