Hello guys, i have annoying problem with a dynamic block in a drawing - when i make a change in the block editor, it doesn`t apply in the model space although i save all the changes. There is also another dynamic block and this time everything is working properly - all the saved changes appear in the model space. The only difference between the two blocks is that the first one has attributes. I think attributes should not be the reason for not applying changes, but i just don`t know what`s wrong, so please if someone has a clue, just explain.
Changes to attributes (addition or deletion of attributes) must be refreshed by using Battman or Attsync I believe. Attibutes, when inserted are not actually part of the block when inserted but follow the block as independent but related entities. It may be complicated because dynamic blocks, when inserted become anonymous blocks if dynamic block parameters are changed. If you have problems floating attribute changes, then reset the block reference either before or after attsync.
without seeing a drawing, this is just a guess.
