I am trying to learn a bit about Autocad Architecture 2014 and seem to have managed to loose my build, section panels in my ribbon, it seems I have loaded the standard ACAD menu from the menuload command. This happened after opening a drawing I found i had "no panels are loaded" message in the panel area. I have loaded several cuix file from the menu command non seen to be the the architecture panels. I also note that my workspace switching shows the selection for straight AutoCad, originally I could not switch as there was only one option Architecture. I still have appropiate tool pallettes.
I am running on widows xp 32 bit, 4 GB ram and as expected I have had several crashes prior to this problem.
I am sure there is a simple answer.
Hi Pendean,
No that didn't unfortunately thoufg Architecture (global) and Architecture (US metric) and Autocad are ubder profile, tried both and just got the"no panels loaded" but ACAd gives me a more classic ACAD UI. Still playing now.
Cheers
Malcolangelo.
