I am having an issue with my AutoCAD Architecture seemingly automatically updating to a different version. This has happened twice to me, I will turn on my computer one day and all of my toolbars are completely different, and do not have any of the typical archtectural tools showing (walls, windows, elevations). Every tool seems to be in a different location and makes it quite time consuming to work through. The only solution seems to be uninstalling and reinstalling AutoCAD, once installed the toolbars are back to normal. Please help!
Solved by pendean. Go to Solution.
You are probably just starting wiht a different AutoCAD/Architecture profile, nothing more.
Next time it happens, do one of several things first before this dramatic reinstall option. It may help if you do these now to document what the current settings are:
- OPTIONS command's PROFILES tab: what is selected now, document. Reselect it if things change again.
- Workspaces: which one are you using now? write it down, next time manually select this workspace and see if things go back.
My current profile is set at the same "AutoCAD Architecture (US Imperial)" profile that it always has been on. My CAD currently is having this issue, so I am not able to document what my prior settings may have been.
I have even reset my profile and it has changed everything except the toolbars.
Screen items like toolbars and palettes are controlled by the workspace: reselect the one you last used.
