At first, i uninstall & re install my autocad 2011 because it does not fully open a un licensed dwg. file. pop up message comes out " this dwg file was save by an application that was not develop or licensed by autodesk"
Then, I change the "dwgcheck <1>" command to "dwgcheck <0>. then the dwg file was open without the pop up message. after that I save the dwg file and it save to the default 2010. When i change the default 2010 file save to
Acad 2000 to 2007 dwg. then Fatal Error comes out. i cannot save to lower version.
Need your help!
JLoa
