AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Autocad Architecture 2010 rendering problem
8 REPLIES 8
Message 1 of 9
mantisbug
720 Views, 8 Replies
Hi, I have the educational version of Autocad Architecture 2010. For some reason, I have problems when attempting to do renderings. I am hoping I can get some assistance with solving the problem. Any time I try to render a drawing, the model screen does something strange. It seems like the layout is showing through in to the model tab. As I move my cursor around, my cursor makes a strange white path. It seems like some kind of strange clipping error where my previous view wants to show through. This happens any time with rendering, visual styles and activating material textures. I am running this program on a laptop and don't know what to do to try and fix it. Perhaps I need to download a new driver or something?
I would really appreciate help in solving this. Thanks,
Zach
8 REPLIES 8
Message 2 of 9
in reply to: mantisbug
System specs?
Sounds like a video card issue. Driver date?
Do you have a dedicated video card or onboard card, or (ugh) shared ram?
Using software/hardware acceleration? DirectX or OpenGL (oops that's gone
isn;t it?)
wrote in message news:6311433@discussion.autodesk.com...
Zach
Message 3 of 9
mantisbug
Hi, thank you for the reply. I don't think the problem is related to the performance of my laptop. I bought it recently...But the specs are as follows. I have a dell insprion 1545.
Processor: Intel(R) Core(TM)2 Duo CPU P8600 @2.40 GHz
Memory: 3.00 GB
Operating system: 64-bit operating system on Windows Vista
The date on my video card is 1/16/2009...I attempted to update my video card driver but it said it was up to date.
It is called Mobile Intel(R) 4 Series Express Chipset Family.
I am not sure if I have a dedicated video card, onboard card, or shared ram? Unfortunately, I am not sure what those are or how to find out which I have.
I did look at the settings on my video card. When I go to 3D settings, it says OpenGL. I notice there are about 10 things that can be changed in the 3D settings.
Message 4 of 9
Sounds like an onboard card built into the mobo but I'm not sure.
Try changing the OpenGL to DirectX and/or software and see if it improves.
wrote in message news:6311524@discussion.autodesk.com...
Memory: 3.00 GB
3D settings.
Message 5 of 9
mantisbug
Well I am not exactly sure how to get DirectX working. I tried downloading the program from Microsoft and it seems like it downloaded and configured everything automatically. I can't find the actual program on my computer so I don't know how it works. It's not the DirectX I remember. Maybe you could point me in the right direction? I downloaded dxwebsetup.exe from microsoft.com
Message 6 of 9
From the OPTIONS>> system tab, 3D - perf..settings, manual tune
Just select DX or SW and ok out. try it out.
Unticking 3D accel.. is software mode.
wrote in message news:6312251@discussion.autodesk.com...
microsoft.com
Message 7 of 9
mantisbug
Hey it finally worked!! Thanks a lot! I really appreciate it!
Message 8 of 9
I would have thought 2010 would have worked with the default install.
So tell us, which one worked?
wrote in message news:6312993@discussion.autodesk.com...
Message 9 of 9
mantisbug
Well it seems my problem was that the hardware acceleration had not been activated. I followed the steps you suggested and when I got to manual tune I noticed little warning symbols by gooch hardware shader, per pixel lighting, and some other settings. So all I ended up doing was checking the box by enable hardware acceleration. After that everything had green check marks so I knew they were working.
”Boost
