1. Download and install Orca from Microsoft.
2. Copy the installation files to your hard drive or a network folder.
3. Backup the files ACA.msi and Setup.ini
4. Edit the ACA.msi with Orca and delete the action found in the table
"InstallExecuteSequence" that is called "CheckFor64BitOS" Delete the same
line under table "CustomAction"
5. Save and close the ACA.msi
6. Edit the Setup.ini with Notepad. Delete the line under
"#==================== Platform Requirement" that is labeled
"PLATFORM=NO_WOW_64_PROCESS"
7. Double-click the Setup.exe and you should be able to install without any
problems.
8. Some support paths under the "Files" tab of the configuration dialog box
have incorrect paths. The installer adds and extra "\AppData\AppData" to
some support paths located in the user profile. For example the Main
Customization File's path is listed as
"C:\Users\%username%\AppData\AppData\AppData\Roaming\Autodesk\ACD-A
2008\enu\Support\ADT" when it should be
"C:\Users\%username%\AppData\Roaming\Autodesk\ACD-A 2008\enu\Support\ADT"
Fix the incorrect paths, hit apply, and you are good to go.
I was able to edit the ACA files with Orca and the relevant lines were there. Then when I tried editing the setup.ini files I did not see the line PLATFORM=NO_WOW_64_PROCESS. What I get is this:
#==================== Platform RequirementI left everything untouched and then tried running the setup.exe and when i click to install I get the same message as before.
OSMAJVER=5
OSMINVER=1
SPMAJVER=2
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
<RaulTT> wrote in messageI
href="news:6293956@discussion.autodesk.com">news:6293956@discussion.autodesk.com...
tried installing ACA 2010in my new Windows 7 64bit laptop and I get the
message "you cannot install this product in this operating system"
Then
I tried following these procedure for ACA 2008:
and Setup.ini
in the table
Delete the same
ACA.msi
problems.
have incorrect
some support
Customization
as
good to go.
#==================== PlatformI
Requirement
OSMAJVER=5
OSMINVER=1
SPMAJVER=2
What should I do to
be able to install ACA 2010 in my computer?
