AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Autocad 2012 text issues on model space
4 REPLIES 4
651 Views, 4 Replies
When creating text in model space it appears both mirrored and rotated 90 degrees to the horizontal. However, when I create text in paper space it is fine. I have tried looking at the properties for the text but although I can find a place to rotate the text back to the horizontal it is still mirrored and therefore unreadable.
When I copy paste stuff from one document to another this also occurs. Any help would be greatly appreciated as I cannot find anything on the internet to help me out.
4 REPLIES 4
pendean
UCS and PLAN variables are set to what in modelspace?
cloudnin
Your ucs is most likely the cause of the problem. Do this: UCS - enter - W - enter - PLAN - enter. That should clear things up, but the stuff you've drawn so far might be wrong. Select it all and copy it to the clipboard first so you can paste it back to your drawing. You could also just copy your work to a new file that has the UCS working normally.
Genius. Thank you. I would never have known about all that.
I am having the same issue but only in certain drawing files.  The dwg came from an outside consultant.  I have looked at the UCS and PLAN variables and both are set correctly.  Any suggestions?!
”Boost
