AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AutoCad Architecture 10, How can you copy blocks to different drawings?
2 REPLIES 2
mshcgnc
309 Views, 2 Replies
2 REPLIES 2
David_W_Koch
in reply to: mshcgnc
Welcome to the Discussion Groups!
There a several ways to copy AutoCAD blocks between drawings.
1.  With the source file open, use the WBLOCK command to "export" the block definition to a separate drawing file.  The, use the INSERT command to insert the file you created with WBLOCK into the target file(s).
2.  You can use DesignCenter to copy Blocks from any drawing to which you can navigate into the current drawing.
3.  You could INSERT the entire source file into the target file.  You could cancel the command prior to actually placing an instance in the target file and still get the block definitions into the target file, if desired.  This might be a good strategy if there are multiple blocks to transfer from the source file and the source file does not contain much more than the blocks to be transfered.  Otherwise you may have a lot of purging to do afterwards.
4.  You could set up a Tool Palette to hold tools that insert the blocks (one per tool), using the source file as source of the block definitions.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
mshcgnc
in reply to: David_W_Koch
Thank you so very much. Your suggestion is helping me greatly.
Best Regards,
Mark Herman
CEO
MSH Consultant Group,LLC
cell: 919-201-3308
fax: 919-882-9209
email:mark@mshcg.com
web: www.mshcg.com
Sent from my iPad
Please consider the
Environment before
Printing.
”Boost
