I work on AutoCad 2012. I am trying to find the revision cloud & tag tool. I seem to only be able to place a revision cloud without a tag on the drawing. I don't see a tag option and searching for the option on the help menu has resulted in zero hits. Does AutoCad 2012 not offer this feature or am I looking in the wrong location? Please help.
Thank You!
Solved by leothebuilder. Go to Solution.
Solved by dbroad. Go to Solution.
The ribbon form of the command will not place a symbol unless one has already been used previously or specified at the command line using the symbol option.
On the document palette, the revision (with symbol) tool inserts a standard revision symbol.
Once the document palette tool has been used, the ribbon tool operates the same way.
Hi.
Im new in autocad. I dont find the revision tag symbol in the tool palettes? Im lost. Can somebady help me with that?
Right click the spine of the tool palette, and near the bottom of the flyout make sure you select Document group.
On the Annotation tab you'll find the revision cloud and tag tool
If you have plain Autocad you're in the wrong forum.
This one is dedicated to Autocad Architecture.
This one is for plain Autocad:
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/bd-p/706
Not sure if there is a revcloud tool in plain autocad.....the REVCLOUD command will work tho.
