I've designed an object using 3D poly, but cannot it to a .stl file since it is not a solid.
Is there a way to convert a 3D poly to a solid, or is there an easier way to create odd shaped 3D items.
This is in an effort to print the item on the MakerBot Replicator Z18.
Thanks for your time.
Solved by MarySeufert. Go to Solution.
Maybe post a picture of the object so we could comment on how to create it...
I've attached the file (I hope).
It is a corner stone on a bridge pier where the vertical face transitions to the nose panel.
Thank you MarySeufert!
I was unfamilair with the LOFT command.
In my attempt I had the "ends" ni place and couldn't connect them, now I can!
This I believe will be the solution to my conundrums!
The file was able to export to an .stl, so tomorrow I will test it and try and print it.
Thank you again for your time.
