AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AutoCAD Architecture 2013 Express Tools Missing Commands
6 REPLIES 6
anikakramer2006
1581 Views, 6 Replies
finally I got my express tools ribbon but a lot of commands are missing....REDIR for example....
I heard I'm not the only one with this problem....
Don't tell  me to reinstall AutoCAD Architcture because I already did it twice!
Don't tell my to select the acetmain.cuix by CUILOAD...because....you know
I also tried the menuload and the appload command but won't load every single lisp routine
from the express folder...can you imagine how many lisp routines the Express Folder has.... what ist wrong here...
AutoCAD Architecture hasn't got such problems with Express Tools.....
need to fix this.
...some ideas?
Cheers Anika
6 REPLIES 6
pendean
in reply to: anikakramer2006
So how did you get the ET continent in your screen/Ribbon exactly?
What happens if you just type EXPRESSTOOLS at the commandline?
You have to tell us what you did, not what you don't want to hear 🙂
anikakramer2006
in reply to: pendean
OK you're right... was a little kind of frustration yesterdaySmiley Frustrated I added "Express Tools" to my installation from the Building Design USB-Stick, I added the Express Tools Ribbon with the command "cuix" to my profile and workingspace, everything looked fine, the icons are all there but as I pushed a button, many of the commands came up with.... unknown command....  I also tried  the command "cuixappend"...but then AutoCAD asks me for icons and I wasn't able to find them.
So I tried another way... I used the command "menuload", but the result was the same. So I started to re- and then install AutoCAD Architecure 2013 again, still the same problem.
Now I checked the lisp routines with the command "appload", they work fine.
I checked: C:\Users\username\AppData\Roaming\Autodesk\ACA 2013\deu\Support and everything about acetmain.cuix
So do I really have to load every single Express Tool lisp routine with the "appload" command?
I hope there will be an other way of solution and this is enough
Thanks a lot,
cheers Anika
pendean
If you have to appload each one, they you did not perform the installation correctly somehow.
ET must find and install itself for every supported application and every profile it finds: normally very automated unless you do it differently.
...if I type "EXPRESSTOOLS" into the command line, it says "unknown command"...Smiley Sad
pendean
That means ET is not installed usually, and may explain why you have to manually load each command.
What is DEMANDLOAD set to?
DEMANDLOAD is set to 3....
”Boost
