finally I got my express tools ribbon but a lot of commands are missing....REDIR for example....
I heard I'm not the only one with this problem....
Don't tell me to reinstall AutoCAD Architcture because I already did it twice!
Don't tell my to select the acetmain.cuix by CUILOAD...because....you know
I also tried the menuload and the appload command but won't load every single lisp routine
from the express folder...can you imagine how many lisp routines the Express Folder has.... what ist wrong here...
AutoCAD Architecture hasn't got such problems with Express Tools.....
need to fix this.
...some ideas?
Cheers Anika
OK you're right... was a little kind of frustration yesterday I added "Express Tools" to my installation from the Building Design USB-Stick, I added the Express Tools Ribbon with the command "cuix" to my profile and workingspace, everything looked fine, the icons are all there but as I pushed a button, many of the commands came up with.... unknown command.... I also tried the command "cuixappend"...but then AutoCAD asks me for icons and I wasn't able to find them.
So I tried another way... I used the command "menuload", but the result was the same. So I started to re- and then install AutoCAD Architecure 2013 again, still the same problem.
Now I checked the lisp routines with the command "appload", they work fine.
I checked: C:\Users\username\AppData\Roaming\Autodesk\ACA 2013\deu\Support and everything about acetmain.cuix
So do I really have to load every single Express Tool lisp routine with the "appload" command?
I hope there will be an other way of solution and this is enough
Thanks a lot,
cheers Anika
...if I type "EXPRESSTOOLS" into the command line, it says "unknown command"...
