Is there anyway to make AutoCAD Architecture 2015 start up like previous versions instead of with the interface that has been added?
Solved by Keith.Brown. Go to Solution.
First screen when you open AutoCAD 2015 is what I do not want. I want to have the option to open as previous versions with a blank drawing instead of menu screen.
If you set your STARTUP variable to 0 it will loadup AutoCAD in the manner that you want. By default i believe it is set to 3 in 2015
