AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AutoCAD 2015 Startup
5 REPLIES 5
twallacemagee
7701 Views, 5 Replies
Is there anyway to make AutoCAD Architecture 2015 start up like previous versions instead of with the interface that has been added?
5 REPLIES 5
Do you mean the Dark Theme? Options > Display tab, use the dropdown at the upper left to change to the Light theme.
If you meant something else, post back with more detail about what you would like to restore.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
First screen when you open AutoCAD 2015 is what I do not want.  I want to have the option to open as previous versions with a blank drawing instead of menu screen.
Keith.Brown
in reply to: twallacemagee
If you set your STARTUP variable to 0 it will loadup AutoCAD in the manner that you want.  By default i believe it is set to 3 in 2015
Keith.Brown
in reply to: Keith.Brown
This is what the AutoCAD Help file says about the startup parameter.
twallacemagee
Thank you I was unable to find that.
”Boost
