I am using AutoCad Architecture 2011. I have been trying to align a single line of text with an arc. When I select the Arc-Aligned Text command from my Express pull down i get an unknown command response in my command line. Also, it appears that many of the commands in the Express pull down have the same result. Can someone tell me how to resolve this?
Solved by pendean. Go to Solution.
At the command line type EXPRESSTOOLS: if you get the same error message then ET was not installed, someone just manually copied the menu for you.
Yep sure enough. My express tools were not installed. Can you tell me how to install them.
Thanks for your reply
AWJ
Repair reinstall ACA through your disk, just put it in and follow the prompts, I believe ET is hidden under custom installation options.
