AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Anotative symbol does not appear
1 REPLY 1
pichette
395 Views, 1 Reply
When hovering my pointer over an annotative object, the annotative symbol does not appear.  This works on my other computers but not this one.  Is it a setting somewhere or is it a problem with the install?  I don't remember if it ever worked correctly or stopped working at some point in my learning process on ACA 2011 over the last 6 mos.
1 REPLY 1
niranjan_kamath
in reply to: pichette
This setting should help you out: Go to the Options by typing the OPTIONS command then:
Options -> Selection (Tab) -> Selection preview -> Check the Box “when No Command is active
This will allow Annotation markup while moving the mouse over an annotative object.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Niranjan Kamath
Autodesk, Inc.
”Boost
