AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
All Tool palettes-Desgin are not active !!
3 REPLIES 3
537 Views, 3 Replies
hi , i downloaded the student educational suite , and when i opened it its give me an error   "The drawing file being opened was not created by a productfrom an
Autodesk Education Suite.If you save this drawing, it will always be
plotted with the following plot stamp.
PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT
It is recommended the you save this drawing with a different name. "
then when i clecked continue  i just can draw some lines put cant to use " Tool palettes-Desgin  "   { walls - doors ,,ect  }  and gives me on the commend   (Style not found in location drawing. Using Standard style.  OR  canceled  )
plzzzzzzzzzzz   help !!!
3 REPLIES 3
KathyMoffa
The Educational message is not an error, but is by design, and is a minor annoyance that will appear everytime you open a drawing.   Your printouts will also contain a message on all four corners that the drawing was produced by an educational product.   It's called the educational plot stamp and is the only difference between the free educational version and the very expensive ($5,000 or so) professional one.
For the second problem, you either downloaded AutoCAD only, or most likely, you downloaded AutoCAD Architecture, but the default profile of the downloaded product is AutoCAD.   To change the profile to AutoCAD Architecture, you need to open Options.  You can find Options by right-clicking in the command line and it's also under the big red A.  In Options, select the Profiles tab.   If you have AutoCAD Architecture, you should see it in the list.  Select it and make it current.
in reply to: KathyMoffa
thnx for replying  put  i choosed the CAD arhc. --->  loading  all ok
put the same problem  when clicking on wall or doors   ( ** Canceled - Educational Plot Stamp in source drawing. **
WallAdd  )  like in the pic,    😞
thnx
KathyMoffa
Ok. Something's wrong with your installation.    Try posting the question in the Installation forum.    Be sure to include your print screens like you did here.  It's at the top of the Discussion forums, or you can click this link: http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
”Boost
