I have a sluggish jerky cursor (and it’s not the operator) when you are NOT in a command and while you are creating your selection set in the command. The cursor jumps and reappears @ ~1 sec intervals so you have to anticipate your mouse move to do anything. OH...and it's only happens in model space.
I tried several settings I found on the internet but nothing works. It's only doing it in 3 drawings right now. The latest one was working fine until ~10:00 this morning, then it started in...no issues before this.
It really makes AutoCAD 2011 basically unusable as it takes 5X longer to complete each command!!! HELP!!!
Any thoughts? This is realy driving me nuts and KILLING my productivity!!!
Bil M
AutoCAD Arch 2011
Win 7 64 bit
2.93 Ghz i7
8gb RAM
NVIDIA GeForce GTX 465
Hi all. I have Acad 2012 x64 installed on W7 with Aero theme disabled. All tool-tips and other pop-up features and other berely useful stuff disabled in acad ( looks like Acad 14 😉 . Only Properties and Layer palletes docked on left side. Bur still, I had serious problems with jumpy jerky cursor in model viewport. It always started after some 15 minutes of drawing. Particulary when working with blocks. Cursor even started to painfully jump if I used Alt-TAB to other programs.
I had enough of this c... ( don't even mention other problems that I had with previous AutoCADs) ! Software for 5000€+ should work FLAWLESSLY on decent PC !!! Very dissapointed with AutoCAD !
So, I checked every singel setting and option (like I don't have nothing else to do) and figured out that holy Layer Palettes was making this mess with cursor. But I need it !
Oh, maybe developer will now say: 'it is Microsofts fault and their .NET framework, but for software that expensive, Autodesk developers should check every single feature on every single possible computer-software setup there exists on the planet !!! I don't know what else thay do with all this quadriliard of $ we buyers give them ?!??!! There is no excuse for shallowness.
We use the Layer Palette as little as possible. Try setting LAYERDLGMODE to 0, this will open the traditional Layer Properties Manager when the LAYER command is used.
It's happening in ACA 2012 as well.
I also just went thru my operating system (WIN 7/64 Pro) turning off everything I could that would impact on speed, emptying, for the most part, startup etc. I am running a new Lenovo W520/i7-2850 2.5 with the NVidia Quad 2000M and 16 gigs of ram so it should run decently fast and smoothly, along with a Dell 2450 monitor so I can see the itty-bitty stuff without having to zoom all the time.
Don
Dunno if this helps...But we had this "jumpy" problem on several computers and downloaded the activex control from the internet, It helped a BUNCH!!
Tonya Sweeting
