AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AEC Steel Objects have no OSNAP in AutoCAD Paperspace
3 REPLIES 3
darrelldixon
260 Views, 3 Replies
We model the building using AEC steel members in AutoCAD ACA. When the piping group xrefs our model into their model (in regular AutoCAD) to add their pipe, the AEC steel behaves properly in model space, but when they go to dimension in paperspace (for example from the center of their pipe to the face of a column) osnap does not recognize the AEC steel geometry. Any ideas?
3 REPLIES 3
David_W_Koch
in reply to: darrelldixon
When transpatial AutoCAD dimensions were first introduced, it was stated that they would not work properly with AEC objects.  It would appear that remains the case.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
ntellery
Make sure layer 0 is on.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
darrelldixon
Thanks for the replies. Layer 0 is on, but as David pointed out, it doesn't matter.
”Boost
