AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AEC Polygons Again
3 REPLIES 3
gary
265 Views, 3 Replies
AEC Polygons Again
So, trying to create a masing polygon for a callout bubble and the polygon changes from curved surfaces to straight segments when I complete the circle.  If I leave a portion of the polygon straight the mask remains curved.  So I made 2 halves of the bubble to mask the entire circular bubble.  If I merge the polygons they become straight segments.
Does anyone have a solution or is this the only workaround?
Gary
3 REPLIES 3
LanceEdwards13
in reply to: gary
Have you found a solution to your problem yet? Can you post a quick sample file of the issue so that we may take a look?
Lance Edwards
Product Support Technical Specialist
Product Support
Autodesk, Inc.
John.W.Mumaw
in reply to: gary
Gary,
I'm not sure how you're going about it but I use circular masking polygons and make them by creating a circular polyline (made by splitting a circle, mirroring, and converting to a polyline) and then converting to an aec polygon.
John
John W. Mumaw
Timber Frame Designer
Lost Bent Woodworking & Design
jmcintyre
in reply to: gary
If it plots as a circle then-
Have you checked the FACETRES and VIEWRES settings?
Do you have a visual style set which could affect the appearance?
”Boost
