So, trying to create a masing polygon for a callout bubble and the polygon changes from curved surfaces to straight segments when I complete the circle. If I leave a portion of the polygon straight the mask remains curved. So I made 2 halves of the bubble to mask the entire circular bubble. If I merge the polygons they become straight segments.
Does anyone have a solution or is this the only workaround?
Gary
Have you found a solution to your problem yet? Can you post a quick sample file of the issue so that we may take a look?
Gary,
I'm not sure how you're going about it but I use circular masking polygons and make them by creating a circular polyline (made by splitting a circle, mirroring, and converting to a polyline) and then converting to an aec polygon.
John
If it plots as a circle then-
Have you checked the FACETRES and VIEWRES settings?
Do you have a visual style set which could affect the appearance?
