This may not be in right place but:
I am currently using ADT 2008. Will this work with Windows 7? Will it work with Windows 7 XP mode?
Also I am trying to find out if ADT 2008 is 32 bit or 64 bit, I believe it is 32 bit, correct?
Thanks for your help
I have not directly used ADT 2008 with Windows 7, but I do have it running on Vista 64-Bit system right now (I wholly do not recommend Vista, I have worked on both and Windows 7 is far superior). The link below mentions successful install and use of 2008 on Win 7. http://forums.autodesk.com/t5/AutoCAD-2008/Windows-7-Home-used-with-AutoCAD-Architecture-2008/m-p/25... . Tip: You should include what version of Win 7 you would be using i.e. Windows 7 Professional, Ultimate....
ADT 2008 itself is not 64-bit, but you can manipulate the install configuration to allow it to install on a 64-bit system. OTB ADT 2008 will not install on a 64-bit system. Below is a link to the info for installation on 64-bit.
64 bit Install Instructions Link
Good luck
TonyD
